Exscom hat geschrieben:Tell me how the plate is centered.
And it is possible to obtain a drawing of the plate. Thanks in advance.
Steffen102992 hat geschrieben:Wow, that's really good work!
You guys know what you to do!
From first pictures I didn't understand how the plate works, but now I understand it.
I think there's no way to do it better!
Big respect!
Steffen102992 hat geschrieben:No idea, it looks like a new version of your Oil pump-plate.... But let me know!
Nagilum hat geschrieben:The plate is quite interesting, since the original differentials can't take much more power (torque) as the stock engine delivers.
I already wreckted 2 "small" differentials, but since these custom parts are hard to get or have to be paid with gold... I guess I have to put myself some more 3.07 into the rack.
jeandersson hat geschrieben:We have the exact same experience. The original differential seems to break once the torque is increased. What we seen is that first the plastic washers inside the differential gets squeezed, which results in a increased backlash and then the gearwheel breaks. From what I seen in other projects the bigger ASD-differential that we are installing now are not affected by the same problems (cross my fingers).
dbr hat geschrieben:jeandersson hat geschrieben:We have the exact same experience. The original differential seems to break once the torque is increased. What we seen is that first the plastic washers inside the differential gets squeezed, which results in a increased backlash and then the gearwheel breaks. From what I seen in other projects the bigger ASD-differential that we are installing now are not affected by the same problems (cross my fingers).
I do not know the original differentials, just W124 ASD, but wouldn't it be possible to replace the plastic washers with selfmade parts made out of metal or a stronger polymer?
Mitglieder in diesem Forum: Bing [Bot] und 14 Gäste
