Marco hat geschrieben:Buona sera Nikola
Yes I confirm that I have both EZL and ECU (with gold label) for ECE management, this was verified with pictures and Johannes’ help who was curious and pushed me to power bank test.
My difficulties are to deal with such poor literature in my hand…see the picture I attach I translated from German look my finger pointing to IACV with 3 pins as you correctly highlight: 2 lines to ECU one to OVP relay and the forth line where is going? Is this where on an original ECE you can play with the idle rev…is this the adjusting wheel you played with it ?
Additionally, difficult to answer but they replaced the manifold with 2 PIN IACV and keeping ECE components, so two alternatives: they put a new wire harness for a 2 PIN IACV or I have a loose pair of cable laying in way of it. I’ll check but is difficult to arrive here to a conclusion, do you agree?
Marco hat geschrieben:I read your PS yes ECE EZL is probably a good point.
I’m not sure if RUF has this possibility but on my it makes a sensible difference if you play with the EZL resistors I feel it driving and was tested the difference at power bank (regardless we say it is trustable but the difference is something we can take): position 1 I reach quicker 240 tachometer then at position 4 that I found when I bought the car. Now I use always 100 octanes for position
Also the fuel distributor I searched in the past and are part numbers for ECE
Best
Marco
shaq hat geschrieben:Marco hat geschrieben:Buona sera Nikola
Buona sera,
4th pin is perhaps 12v connector for some daisy chaining of another sensor (giving it voltage feeding) looks like schematic describing of one pin connector, because on next to it 3 pin components it is always 12v, earth and last wire is controlling signal input or sensor output depending what is the part on schematic. Usually it is the middle pin but dont take my word as fact regarding it - is always better to double check pin numbers in schematic 1, 2, 3 same numbers are engraved on the connector or component itself and even better doublecheck WIRE COLOR.
wire color is never misleading when you try to figure out which is which!
For 2 pin components is almost always one pin ground and another voltage (PWM) controlling its function sent by ECU.
Take picture of idle valve. 2 pin is thick short and silver (aluminum) and 3 pin ECE is again golden (zinc coated) and I will help you identify
This is how ECE idle valve looks. See black wheel on top? It is for manual adjusting of idle on warm engine:
This is how KAT/RuF idle valve looks like. Not adjustable for general public. For professionals little adjustable with that golden screw, but amateurs better not touch it:
To help you understand wires there is german or english 2/2 letters describing wire color. Like BN/WS means brown wire with white stripe on it and every brown on Mercedes is some ground connection, black or red with stripes are 12v and other colors are 99% component input or output depending on its function.
Nikola.
Marco hat geschrieben:I’m not sure if it helps but here the best picture I’ve available…may be the red wires are those related to such connector (but it seems are three not two)
Marco hat geschrieben:Referring to this :
Yes I knew only ECE has there behind battery…I’m wondering what changes you can do for CAT/RUF for the ECU software?
Marco hat geschrieben:As you mentioned differential ratio I commented that I’m quite sure it’s the original 3,07 here I don’t have the car and I don’t know where they write this and I’m not sure what this code means but by chance it end 307…
Then some considerations: assuming the differential is still from ECE I guess that we can keep as reference the attached old test from an ECE where in 5th gear they arrive at 230km/h at 6300rpm, so regardless if the power is enough or not but if my car arrived at 230km/h engine would be at same rpm, am I correct?
Marco
Marco hat geschrieben:Ciao Nikola
Confermo, motori senza cat è un’altra vita![]()
I did not know RUF are rarer than ECE in 2.3 range. Other strange fact is on this forum it looks more common 2.5 than 2.3, despite so lower production number, probably because many 2.3 have been used and abused without regrets till dead…
Very useful info on valve seat and spark plug correct choice, I please just want to correct one think, CAT has hotter spark plug not colder, H6DCO or equivalents are hotter than H5DCO or equivalent. Colder spark plug are usually for higher rev engine and higher combustion pressure so less risk of pre detonation, they dissipate better the heat at most critical condition but can have more dirt in combustion chamber at normal use, hotter spark plug help for cleaner combustion chamber but give more risk to pre detonation because of their hot.
But again it make a lot of sense your explanations why RUF and ECE are both very fine for H5DCO and Mercedes gave me exactly these.
About the manifold yes it’s very likely as you said, they called Stuttgart and be advised to remove the RUF manifold so they can use ECE ECU and ECE fuel distributor and all I still have completely from ECE. There is one formal think that still does not match to me:
car left factory with ECE intake manifold:
PN: A102 141 31 01
But I have now intake manifold:
PN: R 102 141 4401
Grazie
