Dear All,
I have a w201 2.3-16v Mercedes-Benz, but unfortunately it is a KAT. kAT has been removed!
Engine: 102983 12 001332
Besides the high mileage, the compression ratio and the power of the KAT engines are not the best 8,7:1, compared to the ECE engine 10,5:1
I want to overhaul the engine and thinking, if possible to get a bigger capacity and higher compression ratio out of this block.
Like for example, if a 2.5 liters can be achieved out of a 2.3 when machining the bore to its respective tolerance.
Is this possible? I guess yes, Oettinger for example had the 2.6-16v by increasing the stroke and I guess many have already increased the capacity and mounted bigger pistons.
any recommendation?
I would, theoretically, increase the bore to certain tolerance and put bigger pistons and suitable rods and changes the valve cams to Dr. Schrick or Cat Cams for example.
The injection system will be then also adapted to this bigger capacity. I have from a 2.5-16v: KE Jetronic ECU, Injection distributor head, ignition ECU.
Next step, may be the ITB.
thanks in advance for your input.
