Mercedes W201 190E 16V EVO • Thema anzeigen - So....
So....
Beitragvon Racing » 9. Sep 2007, 22:04
Today i just got to go out to the shop and turn around..:(
However,the boys were at it.
Bracketry for the turbo.
As can be seen the AN4 fitting is welded to the bracket and the entire bracket is used as an oilpressure fitting.
Of course the bolts will be replaced by stainless allen ones,and the bracket will recieve some sort of finish...but you at least get an idea.
Racing
Beitragvon Racing » 13. Sep 2007, 21:22
As i´m slowly gettin better the pace at the shop is picking up :)
With that said.
As this will be a more or less high output motor we´re taking ease of service into consideration.
Altho i´m not a fan of "bling" AN parts can´t really be considered such.
This is the real deal.No el-cheapo rip-off,but true aeroquip stuff.
As the new intake will be very short it would interfere with the OEM oilfilterhousing.
Now,the OEM oilfilterhousing-in contrast to much of the aftermarket crap-contains some desirable features like a thermostat worth its name asf.
Therefore,i opted to mod the stock unit.
This was done by taking it apart completely and ripping the OEM steel liners out of it.
Then i turned a replacement out of aluminium that was interferance fit,turned a lid for it-again aluminium-and welded the whole thing back together with AN12 weldbungs.
Going to keep the AN stuff as a nomer on this motor,and as such i also modded the valve cover to take the bungs needed.
Now,the valvecover is out of magnesium and therefore not really an option to weld.
So what i did was to turn some inserts in the lathe that was interferance fit and pressed the whole thing together with pure old fashioned force and a BFH.
As there´s no real pressures involved..it´ll work.
As you can see i opted to drill the "little" one out too,and installed an AN10 in that position.
Idea is to run the AN10 the lenght of the cover and have both the AN10 and the AN12 exit in the same position for the breather box further down the road.
For the cooler lines i opted to get rid of the OEM very soft couplings and install AN12 there as well.
Point again being...i expect this motor to be pulled a time or two as things progress,and ease of service and maintenance is something we build into the project at this point.
Simply turned a set of flares for the OEM tubing for the cooler and reused the OEM steel lines and TIG welded it all back together.
Important is to be aware that the shutter angle of the AN stuff is 37deg.
Exhaust hedder then.
This is the raw material as delivered.
Expensive to say the least,as it is Inconel reinfored acid resistant stainless steel.
Material is BONE tough,and that means that cutting as well as forming it...yeah well...thank god i got a lathe standing around :D
This is the equally stainless exhaust flange for the head.
Watercut.
..and then the weldbungs for the hedder in place.
I formed these by turning a mandrel in the lathe out of aluminium so the end that it supposed to meet the pipe per se didn´t get disformed.
Then used some BRUTE force in a vise...
Turned out pretty good...but boys...don´t try this at home with regular hand tools with this material.You´re BOUND to get hurt.For real!
To go with the ideas of good total system flow we built in an antireversion step for the hedder to aid the exhaust pulses as they´ll be scavenging.
Point being that this intentional step will hinder the return pulse from reaching the exhaust valve undisturbed.
As the roof of the port is the most active part of it,this is where the mismatch is set to be the biggest.
Racing
Beitragvon Rouven036 » 14. Sep 2007, 09:50
looks good jesper!
Rouven036
Beitragvon Racing » 14. Sep 2007, 10:41
Thanx.
Yeah.We´re looking to make downright insane amounts of power this time out.
Found a new car to work on too.
A 91 vintage 16V in astral silber.
Idea is still the "sleeper" concept,just a well maintained one.
Future will tell i guess,and as far as power of this buildup...we´ll just have to wait and see.
Chassis will be modified to boot,and amongst other mods i hope to make and install a full aluminium roll cage.
Got the fresh VEMS Beta box delivered.
Holds a MAP sensor of 5 bars total(IOW capable of 4 bars of boost:) )
Idea is to run dual injector setups for a total fuel capacity of approx 1700ccs of fuel.
Should suffice a bits way i hope.
Racing
Beitragvon Henger » 14. Sep 2007, 10:50
Sieht alles nach einem guten Projekt aus, schöne Bilder mal wieder aus Schweden :D
Weiter so alter Wikinger 8)
Beitragvon Racing » 14. Sep 2007, 10:57
Thanx Frank.
Idea is to make the 16V shine.
We HOPE to superseed 700PS with this one..
Racing
Beitragvon Racing » 14. Sep 2007, 20:30
V-band clamps...raw aluminium...and some serious DIMENSIONS of parts involved...racing gentlemen..racing :D
..and the hedder is getting there,but JESUS this inconel reinforced crap is hard to work with!!
Racing
Beitragvon Nagilum » 14. Sep 2007, 20:39
Looks heavy... :shock:
Beitragvon Maki » 14. Sep 2007, 21:37
Yep - Inconel
Das beste Material für den Krümmer ABER schwer zu bekommen, ** persönliche Ansprache für besondere Kumpels** teuer und sehr schwer in der Verarbeitung !
Beitragvon Racing » 14. Sep 2007, 22:09
Funny thing is....
You light the TIG welder up(WIG)...you REALLY put the WIG to the material...and approx 30 seconds after it being molten hot...you can pick it up with your bare hands..:)
Like i said..RACING...for real...
Racing
Beitragvon Dennis190D » 14. Sep 2007, 23:01
Hoi Jesper!
Ich drücke die Daumen, dass bei dem Projekt alles glatt läuft :-) Wo ist die Warteliste für die Plätze als Beifahrer? :lol: Freue mich schon auf den nächsten Skandinavien-Urlaub 8) Hoffentlich ist es dann trockener :cry:
Ciao Dennis :wink:
Feuer und Seide im Fuhrpark:
Dennis190D
Beitragvon Racing » 15. Sep 2007, 23:54
Racing
Beitragvon Racing » 17. Sep 2007, 20:44
Racing
Beitragvon Dennis190D » 17. Sep 2007, 20:52
Ich frage mich grade echt, wie das in den Motorraum eines 190ers passen soll :kratz
Ciao Dennis
Dennis190D
Beitragvon Nagilum » 17. Sep 2007, 21:01
Beitragvon Racing » 17. Sep 2007, 21:06
Racing
Beitragvon Racing » 18. Sep 2007, 21:29
Racing
Beitragvon Rouven036 » 18. Sep 2007, 22:09
wow :shock: ,if its possible for me to buy a cheap 16v i will bring it to you jesper!
i want also a "snake farm" under the hood
absolutly gorgeous!
Rouven036
Beitragvon Henger » 18. Sep 2007, 22:22
Beitragvon Dennis190D » 18. Sep 2007, 22:42
Dennis190D
VorherigeNächste
