Mercedes W201 190E 16V EVO • Thema anzeigen - So....
So....
Beitragvon Henger » 16. Okt 2007, 20:55
Beitragvon Racing » 16. Okt 2007, 21:14
Racing
Beitragvon Racing » 17. Okt 2007, 23:07
Getting there Frank...getting there...
Racing
Beitragvon Henger » 18. Okt 2007, 10:30
Hab die Bilder mal nebeneinander eingestellt zum besseren Vergleich.
Bild[/quote] Bild
Beitragvon Racing » 18. Okt 2007, 20:14
Yup..it´s all in a days work as they say.. :)
Anyways.
Continued a little today.
Again..for the sake of comparsion.
My modded head vs an OEM 2.5-16
..and then...the intake side.
versus the OEM 2.5-16.....
Intake ports have mainly been opened up diagonaly upwards/inwards-and frankly speaking there´s a LOT more to it than meets the eye.
The venturi now measures in at 29.5mm and entrance is at 33..
Racing
Beitragvon Racing » 8. Nov 2007, 21:54
Anyways.
Todays crop then.
New plenum.Ample volume and with the homebrew intake stacks next to it.
The one to the right is still in the "raw".
Everything in sight is made up from 3mm gauge aluminium.6082 to be more exact.
..and as can be seen full radii of course.
As i cut the OEM oilfilterhousing down..i needed a new adapter for an OEM Merc filter,and then of as minescule proprtions as could be had.
This is the result,and again of course with AN12 weld bungs.
Yup..even e small bracket so we can bolt the POS up where we find space :lol:
Thing is..when done a LOT of the aluminium pts will get a turnaround trip for the anodizer bath..so don´t fret as far as finish go just yet.
Racing
Beitragvon Racing » 10. Nov 2007, 23:52
So...back home.
The 2.5-16...followed me home :P
Jesus...why do people never learn?
Up here..it´s turning into winter in a hurry.
Snow..sub zero asf..
Well...as we got to "Flen"(name of the place where the car was at)..we were greeted by a car in ever BETTER condition that i would ever have anticipated seing what the owner was asking.
However..the car had a MAJOR flaw as stated...it wouldn´t start.
After some basic diagnosis..we concluded the car was running way way rich...however..
For those of you into the loop on K-jets...car came to life after backing the CO adjustment screw out SEVEN TURNS!!!!!!!!!!!!!!!!!
Buuuuuuuut...with those SEVEN turns backed off...it idled and ran like nothing would stop it :lol:
So..seing that the car was taken off the road(probably due to the Kjet probs) it wasn´t really legal to drive it back on its own behalf...now was it...
Now..i own several cossies as you know,and...tic tac toe..the car was one turbocharged 85 vintage from gothenburg :D Street legal and all...
Turned the key..and started for home.
We obviously did SOMETHING right with the KE..cause it topped out 180km/h in third with ease!(it´s a 4 speed slush box car)
Any rust?
Of course,but very very minor...seing its a 91 vintage 2.5-16 i´d say its in remarkable shape!
Interior for the lack of better words looks like almost new...very VERY well taken care of.
Option list is a bit "odd" to say the least.
This being a "leichtbau" car-meaning it lacks sunroof,which is prefarable to me as that leaves more headroom when i install the roll cage.
It lack rear headrests..lacks leather...
On the other hand its got an automatic gearbox,AC and en electrical seat?
Whatever in essence,cause this is a chassis that is EXACTLY what the Dr ordered as far as i´m concerned.
It being a slushbox car also meaning that the sheet metal of the car will be less strained from previous use than a stick car.
It WAS one serious 500 mile roundtrip tho...and i´m honestly beat..
More?
Of course..as i said i´ve continued work on the plenum for the new motor.
Next up are the stacks to be welded to it...and then the diffusor aso..
Racing
Beitragvon Henger » 11. Nov 2007, 01:13
Hi Jesper,
freut mich daß du einen neuen 16er gefunden hast :D, die Farbe ist auch sehr schön, den Lude wird es freuen :D
Es ist immer erfreulich, wenn das Auto das man kaufen möchte, sich besser als erwartet herausstellt 8) :D
Der Wagen hat doch eine sehr gute Basis für dein Projekt, die Ausstattung finde ich auch soweit Ok.
Wenn der Preis auch noch gut war, dann hast du ein gutes Geschäft gemacht.
Ein paar Bilder bei Tageslicht mußt du allerdings für uns noch nachreichen.
Beitragvon LUDE » 11. Nov 2007, 01:14
The gearbox is great!
I like my automatic gearbox. And there is noting better when you drive in the city with mutch traffic.
But thats not really the way that you like or need Jesper!?
Beitragvon Racing » 11. Nov 2007, 08:57
Frank.
With everything said n done i paid 1800 euros for it,so...yes...i´m happy.
Point being that what i was after was a car WITHOUT sunroof for the "uberoll käfig" i plan to make out of aluminium to have room,and automatic car-as that will bring that the chassis/sheet metal is less stressed than for a stick car aso aso...so all in all i couldn´t have found a better object than this in my opinion.
Silver....as it´s what mercedes once used for their race cars..
Lude.
Nope..you´re correct..the gearbox is the least of my concerns...let´s just say there will be one...surplus as time progress ;)
Racing
Beitragvon LUDE » 11. Nov 2007, 12:55
Beitragvon Racing » 11. Nov 2007, 19:26
Lude,so will i!!!
Well...if you need it...be my guest!
After the next couple of weeks as i start diggin into the car...it sure as hell is of no use to me anymore.
Spent the day with the newcomer as it didn´t run all that well and i want to be able to drive it a little to get a feel for it b4 i start chopping into it.
As ususal...the world is full of "experts".
Sure enough..some "expert" had adjusted the KE...however out of reasons NOT so apperant at first.
1/Only the first inline of the two fuelpumps was working.
Tossed them both out of there and replaced with one singular early series 16V pump.
Problem solved.
2/Took the valve cover off to check valve timing and valve clearance.
Turned out that-again-some "expert had changed the camchain because it was 2 full cogs to early.
So..adjusted that..
3/Now..as i have a number of spare KE units laying around i saw no reason what so ever to try n rectify what some idiot had destroyed as far as adjustment..so i installed a known fresh one.
Adjusted the CO...and...
Presto!!
We´ve got a very nice running 2.5-16 :D
Now..i´ll drive it for a couple of days and take care of various probs as they come to get a feel for the car.
Btw Lude.
Gearbox works just fine.
It´s HAS been worked on at some occasion as can clearly be seen by the modulator.There´s RTV(silicone) by it.
Further,it leaks ever so little from the pan gasket.
Racing
Beitragvon Racing » 12. Nov 2007, 22:09
Spent some more time working on the car today,and we´re getting there i´d say.
Even got the SLS to work after changing the link for the "nivaueregler",but as i did that...and got the SLS to work again..i´ve got this ticking sound from it and you can even SEE how the pressure hose at the engine reacts to the pressure differences.
Whatever kind of...but still..
Ride is as it should be as is roadholding i´d say.
Got the ASD working too..
Fixed one of the switches for the electric seat adjustment.
Changed a number of broken instrument lamps..
Drove by a friend and picked up a new blaupunkt CD player,and it turned out that there IS a set of decent speakers in the car already-and i sure as hell ain´t gonna use the car to win any stereo contest with anyways...
Checked valve clearance on the engine and fiddled around with the CO and idle a bit..and it´s starting to run very very well indeed for a stocker i´d say,and for an automatic even more so.
We´re getting at the point where we´re going to turn this thing here into something it ain´t at the moment.
Capable of WARP SPEED :shock: :lol:
Racing
Beitragvon Henger » 12. Nov 2007, 22:18
Hey Jesper,
endlich haste mal eine ordentliche Karre zum fahren :wink: und schön ist er allemal.
Du bist ja richtig begeistert von der Technik (wenn sie funktioniert), sogar der KE kannst du was abgewinnen :shock: ....vielleicht solltest du mal umgekehrt verfahren...Umbau von EFI auf KE :shock: :lol: :lol: :lol:
Bitte mit vielen Bildern dokumentieren :wink:
Spass beiseite, wünsch dir viel freude mit deinem Neuen 8)
Beitragvon Racing » 12. Nov 2007, 22:56
*lurks on with an evil eye on Frank*...;)
Frank.
The car might as well enjoy the last days of its life as a mundane passenger car WITH the KE onboard...cause it sure as hell ain´t gonna live especially long like that..
You know what they say..
Any idiot can restore a car.
It takes a REAL man to carve one up! :D
...and will we EVER carve this one up...
Thanx tho Frank,and yeah...i´ll take pics as we strive along with the project.
Rest assured.
Racing
Beitragvon Racing » 27. Nov 2007, 00:20
Kim paved the way...so..
Sponsored by our local mercedes benz retailer up here for the upcoming car.
Racing
Beitragvon Henger » 27. Nov 2007, 00:32
Ohhh welch eine feine Bremse, auch haben will mag mögen tun wollen sabber :mrgreen: :mrgreen:
Sieht scharf aus und ist sicher brutal :hau
PS. sehr schöne Zutaten hast du bei deinem Umbau diesmal dabei, angefangen vom Turbo über das schöne Silber und nun auch noch ne ordentlich Bremse 8)
Beitragvon dennisbots » 27. Nov 2007, 00:33
hmm that will stop the car i think
are those 350mm disc's?
dennisbots
Beitragvon Dennis190D » 27. Nov 2007, 00:34
Hi Jesper!
Sweet little brakes 8) I'm looking forward to my next holidays in Norway/Sweden :D
Bye Dennis
Feuer und Seide im Fuhrpark:
Dennis190D
Beitragvon Racing » 27. Nov 2007, 00:43
Racing
VorherigeNächste
